PhoenixFD 3.0 doesn`t handle user defined properties correct
  • PhoenixFD 3.0 doesn`t handle user defined properties correct
    PhoenixFD starts putting it`s own user defined properties on the same line as the previous entries.
    As you can see in the screenshot, "theUDIM=1001" was written by me some time ago. On the same line, PHXFD continues with its own keyword. I don`t know if this causes problems for phoenix, but it certainly does for me.
    PS: I can fix it quickly with maxScript, so it`s not a huge issue for me
    Hey,
    Thanks for catching this! I think it's a max thing though, since Phoenix gets and sets these through max and the newlines don't reach the Phoenix code so we can parse them and allow proper editing. I guess the workaround would be to always end your properties with a newline.
    Cheers!
      Can`t Phoenix run a maxScript code or something to make sure it gets correct? Like some sort of cleanup ... I know its ugly, but its better than nothing.
        If we had access to the entire text we could do anything, but right now we just ask Max: "Max, do you have *that* user prop?" - "Yes/No" - "Okay, give us the value of that prop" - "Here you go" - and that's pretty much it.
        I'm gonna check if there is some other way to do it
          Yup, seems like 3ds Max just does not sanitize the properties string before editing it through the SDK - you will have the same issue with the V-Ray per-node props as well, unless you place a newline at the end. Will file this issue into our bugtracker as there is a way to work around it, but it's rather hacky.
            Alright, got it! Will be in tomorrow's nightly
              We had the same issue with the V-Ray proxies and some user-defined properties that they write...
